• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Can you tell me if these Pc parts are compatible?
henry_k
34
Hey Guys!
I was just wondering if any of you could tell me if these parts don't work together (And if you could tell me which parts don't work and some that I could replace them with that would be great!)
Parts:
CPU: Intel Core i7-4790K Haswell Quad-Core 4.0GHz LGA 1150 Desktop Processor BX80646I74790K
Motherboard: ASRock Z97 Extreme 4 LGA 1150 ATX Intel Motherboard
Memory/RAM: Crucial Ballistix Sport 16GB DDR3-1600 (PC3-12800) CL9 Dual Channel Desktop Memory Kit (Two 8GB Memory Modules)
Hard Drive: Kingston SSDNow V300 240GB SATA III 6Gb/s 2.5" Solid State Drive (SSD) SV300S37A/240G
Case: Corsair Carbide Series Spec-02 Mid-Tower ATX Gaming Computer Case
Power Supply: Corsair CX Series CX750M 750 Watt ATX Modular Power Supply
Graphics/Video Card: MSI Radeon R9 270 Overclocked 2048MB PCIe 3.0 x16 Video Card
Operating system: Microsoft Windows 8.1 32/64-bit Full Version
If you could tell me if these parts are compatible that would be great!
-Henry
chrisb99
360
37
they are compatible but i would get a different case With more fans. i would get a different Board than Asrock as they tend to be less reliable. i would also get a after market cpu cooler so you could overclock good
Snagged
316
You may want to think about a different PSU. I heard the CX series Corsair PSU's used poor capacitors. I could be wrong though. Someone better in the know can chime in on that.
Snagged
316
I was referring to the power supply and not the case. I have no clue about the case. Usually the case a personal choice.
henry_k
34
So can you give me a suggestion?
henry_k
34
Thanks for the suggestion!
Snagged
316
I wouldn't be a good source for that suggestion really. However, I do know EVGA G2 series power supply (PSU) is a good one to go with. I just ordered a 750W EVGA G2 myself and in the process of putting that into my new build. It is a bit pricey.
henry_k
34
Here how about this gaming build?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor
Motherboard: Asus H97-PLUS ATX LGA1150 Motherboard
Memory: Crucial 16GB (2 x 8GB) DDR3-1600 Memory
Video Card: PNY GeForce GTX 970 4GB XLR8 Video Card
Storage: Kingston SSDNow V300 240GB SATA III 6Gb/s 2.5" Solid State Drive (SSD) SV300S37A/240G
Case: Raidmax Vampire ATX Full Tower Case
Power Supply: Corsair Builder 750W 80+ Bronze Certified ATX Power Supply
Operating System: Microsoft Windows 8.1 (32/64-bit)
Does this work?
TofuLion
Admirable
Oct 10, 2014
1,761
243
i agree, build is unbalanced. judging from the parts i'll assume your budget is 1000USD so i'll build from there. and also assume your desired resolution is a single 1080p @ 60 Hz.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($214.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($25.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($132.99 @ SuperBiiz)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($101.98 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($43.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card ($326.99 @ SuperBiiz)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case ($38.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($56.99 @ SuperBiiz)
Total: $1002.86
Generated by PCPartPicker 2015-02-10 01:22 EST-0500
henry_k
34
TofuLion can I make the CPU a intel Core i7-4790K Haswell Quad-Core 4.0GHz LGA 1150 Desktop Processor BX80646I74790K
( I'm going to play minecraft and I LOVE lots of fps) And the Memory a bit better (I need 16GB pls) and the SSD to be 6GB/s writing speed
Everything else is GREAT thank you SO much!
if you could see if that would be alright you would be AWESOME
-Henry
TofuLion
Admirable
Oct 10, 2014
1,761
243
well is your max budget $1000 USD? if so, then not without lowering you GPU which is essentially more important than anything else. also, if this is just to play minecraft, you don't need any of those parts, and could get just as much performance for half the price. it would be the difference between 100 FPS and 300 FPS (which wouldn't matter most displays are 60 Hz meaning 60 FPS max).
TofuLion
Admirable
Oct 10, 2014
1,761
243
again, this is quite overkill for minecraft. but as you wish.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($321.99 @ SuperBiiz)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory ($116.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($101.99 @ Adorama)
Case: Corsair 200R ATX Mid Tower Case ($57.99 @ Micro Center)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply ($63.99 @ SuperBiiz)
Total: $1192.91
Generated by PCPartPicker 2015-02-10 17:09 EST-0500
also upgraded the PSU and the case is much nicer.
henry_k
34
O
M
G
Thank you so MUCH!
I have been saving for a computer forever and now I know what to get
TofuLion you are so awesome thanks again! (It's fine if it's over 1000 USD :D)
-Henry
Similar threads
