Can you use a Powerline ethernet connection for wifi
Oct 30, 2018
I have Powerline in my home. I want to be able to broadcast wifi from the Ethernet port in my room, instead of using a booster or installing another coaxial cable. The main wifi network downstairs doesn't reach the fourth floor. Are there routers that use Ethernet as a source? If not, what is the closest alternative/best option? Thank you!
asoroka
1,201
228
Yes.
You can get a Wifi router that has ethernet port.
You run it in Access Point mode.
It then gives you Wifi cover that then feeds down to your main router via ethernet.
I use a pair of ASUS RT-AC68U to do exactly this.
