Canbelkin n150 Adsl modem router to be used with ISP with Ethernet cable?
Deepak11
Commendable
Mar 29, 2016
I have a belkin n150 wireless modem router which was previously used for Internet with bsnl and now I have switched to another ISP which is Ethernet cable. So is it possible to use my belkin n150 modern router to be used as router only with Ethernet cable?
No. You will need a new router. This is why I recommend always using a separate modem and router. Then the router can be used with any ISP.
You may be able to use the Belkin as a WIFI access point with an ethernet cable back to your primary router if you need additional WIFI coverage.
