Depending on how long its been since you cleaned, one can might do it but you're likely going to use around 3. On some especially dirty cases I've gone through a brick of 6 (setting fire to that case would have been easier). Also as the cans are used, you'll need to let the rest to recharge. My advice would to go to a big box warehouse like Costco and get a pack. Out here a pack of 6 runs about $15 and you wont have to worry about running out mid way though cleaning. If your only option localy is something like radio shack, then buy online. $10 a can is absurd.
As for what to clean, Robert had the right of it. Especially with the fans, its tempting to just blow them and let them spin but I've snaps a blade off a fan doing that. If the...
