Archived from groups: comp.periphs.printers (
More info?)
thank you, Burt! a real answer.
On Fri, 17 Jun 2005 22:45:10 GMT, "Burt" <sfbjgNOSPAM@pacbell.net>
wrote:
>Judy - go on to the following two sites and read their information about
>printer maintenance (primarily Canons). First read their cleaning
>suggestiong and then, if you still have questions or a continuing problem,
>sign in and ask any questions you have on the Nifty-stuff forum. You should
>try one deep cleaning cycle before you do any of the more involved cleaning
>tasks and then run the printhead test. Of course, the other problem might
>be a cartridge that isn't feeding ink properly, so it would also be wise to
>try a new cartridge before doing anything more complex.
>Although there are some poor quality aftermarket inks you should avoid, head
>clogs can occur with OEM and non-OEM inks. Best to study these sites and be
>more educated with regard to avoiding the problem as much as possible and
>fixing it when it happens.
>http://www.nifty-stuff.com/forum/
>http://www.neilslade.com/papers/inkjetstuff.html
>"Judy Cosler" <jcosler@starpower.net> wrote in message
>news:n926b1pddud6oid1dtjkc4he4bafhoe1j7@4ax.com...
>> one of my Cyan nozzles is semi-clogged.
>> i've done many nozzle cleanings. not a deep cleaning.
>> any suggestions? (it's the one that prints out under 'B')
>> tia
