O obik_2000 Jan 24, 2019 7 0 10 Jan 24, 2019 #1 I have an ASUS P8H61 mother board. Core i3 processor. Connected a 600w PSU. It will try to power but go off. Try again and goes off. Changed the board and upgrade to PSU 750W and it still persist. What should I do??
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Jan 24, 2019 #2 Do case fans spin if disconnecting the CPU 4 pin cable and starting the board? Upvote 0 Downvote
O obik_2000 Jan 24, 2019 7 0 10 Jan 24, 2019 #3 alexoiu : Do case fans spin if disconnecting the CPU 4 pin cable and starting the board? Upvote 0 Downvote
O obik_2000 Jan 24, 2019 7 0 10 Jan 24, 2019 #4 It spins and stop spin again stop. And can't spin continuously Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Jan 24, 2019 #5 It might be a CPU issue. Have you checked the CPU socket if any bent pin? Upvote 0 Downvote
O obik_2000 Jan 24, 2019 7 0 10 Jan 24, 2019 #6 alexoiu : It might be a CPU issue. Have you checked the CPU socket if any bent pin? Upvote 0 Downvote
O obik_2000 Jan 24, 2019 7 0 10 Jan 24, 2019 #7 The fan has started spinning continuously after changing the processor but cannot display on the monitor. Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Jan 24, 2019 #8 Are you using a graphics card? What processor installed? Upvote 0 Downvote
O obik_2000 Jan 24, 2019 7 0 10 Jan 24, 2019 #9 alexoiu : Are you using a graphics card? What processor installed? Upvote 0 Downvote
O obik_2000 Jan 24, 2019 7 0 10 Jan 24, 2019 #10 Intel core i3. Yes iam using a graphics card Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Jan 24, 2019 #11 Some i3 CPUs require a BIOS update. See if yours is supported. Upvote 0 Downvote
