Cannot remove norton ghost 12.0 (TheInstallScript engine is missing)
DaveB_55
48
Whenever I try to run the uninstaller for it on add/remove programs, I get an error message that says "The InstallScript engine is missing from this machine. If available, please run ISScript.msi". I found a solution on google where I would delete C:\Program Files\Common Files\InstallShield\Driver\7 and install ISScript7.msi and that would fix the other persons problem, but it didn't work for me... I also used the search function on my computer and it didn't find anything for norton ghost, nor did I have Symantec in my program files folder. Could me removing it from the program files folder have caused this problem? Any help is appreciated, thanks in advance.
