Canon DSLR camera battery help
ovadiaitay34
80
Hello I just bought a new canon 1300d=t6 camera.
I want to buy a spare battery so I looked on amazon. I saw some batteries that have 800mah and some that have also 1600 (almost double)
Is that possible if both of the batteries have the same size?
Thanks!
If they are specifically for that camera they should be the same physical size, only different capacities (the "larger" should last longer)
Always check reviews of sellers and products, wouldn't want to end up buying dodgy ones 😉
