Question Canon G7000 printer on TP-link Deco mesh problems
Greatwhitewing
15
Couple weeks ago swapped over to the DECO mesh 3 node setup which works great. Now I cannot get my printer to connect. Tried reinstalling drivers and rerunning setup program for the printer, nothing works.
Do any other devices have connection problems?
Does the printer respond to pings or otherwise appear as a network device?
Did the printer initially connect and worked. Or has since stopped connecting and will no longer works?
Will the printer work using wired connection?
Reactions: Greatwhitewing
Everything else works fine
I just tried putting the old router back on and printer won't connect. Yet another POS printer that gets tossed. Seems to be planned obsolescence.
Wired connection doesn't work either. Try a factory reset if I can.
I found out after I posted there were a few prints made since the network upgrade.
Be fun beating the crap out of it to take up less space in the trash.
