J jmoon1953 Reputable Mar 23, 2014 4 0 4,510 Mar 23, 2014 #1 hi my i965 is flashing orange (5 times) and then green (1) constantly - is this a print head error and if it is how can I fix it? Jean
Solution scout_03 Mar 26, 2014 google this any if any of the solution will help https://www.google.ca/#q=resetting+i965+printer
scout_03 Titan Ambassador Feb 18, 2010 30,587 324 107,640 Mar 23, 2014 #2 try this http://electronikmade.blogspot.ca/2011/04/how-to-reset-waste-ink-tank-for-canon.html Upvote 0 Downvote
J jmoon1953 Reputable Mar 23, 2014 4 0 4,510 Mar 24, 2014 #3 scout_03 : try this http://electronikmade.blogspot.ca/2011/04/how-to-reset-waste-ink-tank-for-canon.html Upvote 0 Downvote
J jmoon1953 Reputable Mar 23, 2014 4 0 4,510 Mar 24, 2014 #4 Hi scout_03 - thanks for replying to my query regarding my Canon i965 issue. I did try as you suggested to re-set it but sad to say it hasn't solved my problem but thanks so much for your help. Jean Upvote 0 Downvote
scout_03 Titan Ambassador Feb 18, 2010 30,587 324 107,640 Mar 24, 2014 #5 if the last answer in the private message does not work ,it is time to look around for a new printer . Upvote 0 Downvote
J jmoon1953 Reputable Mar 23, 2014 4 0 4,510 Mar 26, 2014 #6 scout_03 : if the last answer in the private message does not work ,it is time to look around for a new printer . I'm still hoping that someone else out there has heard of this problem and fixed it? Thanks again - Jean Upvote 0 Downvote
scout_03 Titan Ambassador Feb 18, 2010 30,587 324 107,640 Mar 26, 2014 Solution #7 google this any if any of the solution will help https://www.google.ca/#q=resetting+i965+printer Upvote 0 Downvote Solution
