I just build a new PC and I am having serious issues with the fans. I have a Corsair 400c, and it has 5 fans installed. The fans I have are the 2 pre-installed fans; a Corsair 120mm and 140mm, along with 3 Corsar AF120 Quiet Red LED fans spanning the front of the case. I am using the Gigabyte Z170X Ultra-Gaming Motherboard, and I cannot seem to control the fans. The motherboard has "Smart Fan Control", where I can set up custom cooling curves for my fans. It seems to recognize the fans, because it will display the RPM of fans, but when I adjust the curves, even setting them outright to zero, nothing happens for most of the fans. The weird thing is that 1 or 2 of the fans would completely shut down, but others would be completely unaffected and keep running in full speed. I also tried SpeedFan, the software I used to control fan speeds with my previous MOBO, but it does not seem to identify any of the fans. With much desperation, I ordered a Silverstone PWN Fan Controller and connected all of my fans to it. They all run correctly now, except for the fact that I have zero control of their speeds. I am very, very frustrated right now, and any help would be great.
PS, all fans are 3 pin, and the fan controller plugs into a single 4 pin connector and a sata power cable.
Links to products:
https://www.amazon.com/gp/product/B00VNW556I/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
https://www.amazon.com/Corsair-AF120-Quiet-High-Airflow/dp/B00F6S0XJO/ref=sr_1_1?ie=UTF8&qid=1480462590&sr=8-1&keywords=corsair+air+series+af120+led
Links to products:
