Can't burn 96kHz / 24-bit / 6 channel DVD audio using WaveLab 6?
superkrups20056
22
Hi guys, I'm getting an error when trying to burn 96kHz / 24 bit / 6 channel audio using Wavelab 6:
(sample rate [96,000]) x (# of channels [6]) x (# of bytes per sample [3]) ---- exceeds 1,260,000. This is not supported by DVD Audio specification.'
I was under the impression that DVD Audio DID SUPPORT 96kHz / 24 bit audio. According to the DVD-Audio Wikipedia article (http://en.wikipedia.org/wiki/DVD-Audio#Audio_specifications) the corresponding box between 5.1 and 96kHz is green. Furthermore, under the Sampling Rate Wikipedia article (http://en.wikipedia.org/wiki/Sampling_rate) DVD-Audio is specifically mentioned under 96,000 Hz.
I'm confused. What is going on? I don't want to downgrade the audio to 48kHz. Thank you.
