[SOLVED] Can't change fan speed
29
I have an i7 6700 Hq 3.10 GHz, and my laptop which is a dell precision 3510, I a having an issue with controlling my fan speed. I cant adjust my fan speed by using speed fan and I have tried all the other application but nothing seems to work here! I even went in my Laptop bios but there is no option for changing the fan speed pls help!!
Reactions: modad
I tried it it doesn't work on my laptop
check if your motherboard supports smart fan control, if you can hear your fans speed up and slow down in your daily use that's a good sign, and if your mobo does support smart fan control then there could be some kind of mistake in speedfan or maybe that app is just not for your pc.
