Cant connect rosewill blackhawk "power led" to ASUS p9x79 mobo
starquake
I have a question about the Rosewill Blackhawk case and its 3 pin "power led" connection from the front of the case. I am supporting an ASUS p9x79 pro mobo and am wondering how to connect it, for that matter if anyone has instructions on connection the front chassis to the this specific mobo.
The power led is polarity sensitive, +connects to + and - connects to minus. Turn the plug around and try again. These connectors are usually ganged with some othe pin connectors near the front lower edge of the MB. Does the MB have 2 pin connectors for power and reset switches? Did you recieve a pin header to connect the entire MB front panel to the case front panel connectors.
Sounds like a new MB. READ THE MANUAL!
