Can't connect surround sound to my LG TV but the sound system
Shawain77
Commendable
Sep 25, 2016
The surround system needs to go in audio out ports but thare is not on the TV there's some other port I'm thinking I may need some other cable or adapter or mabey its just impossible? I obviously can't pull it in without another attachment but these are Bluetooth speakers as well but I can't get my TV to connect to the Bluetooth ether.
Without makes and model numbers we can't give you an exact answer,
If the TV doesn't have audio or headphone outputs you can't connect to it. You would need to get the audio from your external sources directly to the surround sound. An HDMI input selector with audio extraction might help.
http://www.monoprice.com/Product?p_id=5557&kpid=105557&gclid=CPPY2sLnwcYCFYIXHwodhY0FTw
but it won't get you audio from the TVs built in tuner or smart functions.
It is possible to install an analog audio output on a TV but it would void the warranty. You would connect a speaker to line level converter to the wires connecting the TV internal speakers. Not complicated electrically just takes a little thought to do neatly.
Don't think it has an HdmI on the surround sound
