Hi.. i take it you intentionally blanked out the local ip and subnet etc? use subnetcalculator.com to check your gateway and host are in the same subnet.
You can also try telneting to port 80 on the router ip, if it cant connect the router isnt listening for http connections. If it connects then hangs all is ok.
when you say you reset the router... have you factory reset it?
Alright, I assume if you just got a new one two months ago you probably have the IGW 3000. According to the documentation, depending on how it was set up, or if it functions as a DNS server you "should" be able to reach it at either http://igw3000 or http://igw3000 100.73.0.1
wont work it just sets igw3000.com and says the website dont exsist 😛
and resetting dosent work 🙁
