Hello
Display device : NVIDIA GeForce GTX 1660 Ti on TU116-A GPU (with Arctic Accelero cooler attached)
Display driver : 511.65
BIOS : 90.16.20.00.89
My issue is, I cannot control my GPU fan speeds through Aorus/MSI afterburner
the GPU is running on very low fan speed but as soon as I move the fan bar to any position in the apps, it cranks up to 100% fan speed and gets stuck on full speed
Safe mode makes it run on very low fan speed
The temp sensor is working fine, checked it under load
I've tried :
Reinstalling drivers through DDU safemode
Resetting cycle (10s power button when PSU turned off)
Making sure the connections are good and resitting the GPU
Anyone has any idea on what the issue might be? Do I need a seperated fan controller?
I've tried :
