[SOLVED] Can't enable onboard graphics for multi monitor
May 10, 2020
4
Hey guys, I have a A320m-HDV R3.0 and I'm trying to enable onboard graphics so I can use my seconds monitor on it. The only things I have found online for multi monitor are in the bios chipset settings and the north bridge settings but neither of these have the option. please help!
Forgot to add this. I have one of the monitors plugged into my GPU (only one hdmi port) and need to plug the other one into my motherboard
What other ports does your GPU have? If you have an available DVI-D, DVI-I or DisplayPort, you can use an adapter cable to plug the second display into your GPU.
-Wolf sends
AMD Ryzen 3 1200 Quad-Core Processor. Also side note not sure if this is important but previously with the same computer I had used a monitor that had vga and had that plugged into the motherboard with the hdmi in the gpu and it still worked. I no longer have that monitor/cable
Just as an example:
-Wolf sends
