I need some serious guidance...I've had major issues with my Pro Tools 11 (DAW) working so I had went through a series of steps to try and fix it and/or alleviate the issue. I'm going to try and cliff note this so it's a bit easier to understand...
-PT 11 stopped working, discovered my OS was corrupt (Windows 8 OEM)
-Attempted Command Prompt "RestoreHealth etc..." FAILED
-Attempted to Clean install (after Restore was irrelevant) and I was "error"ed at every attempt
-Upgraded to Windows 10 (free version from friend :-| ) and I failed to realize that Pro Tools 11 wasn't compatible.
I was disheartened and gave up. A few months later I tried to fix my issues again with unrelenting dedication. Unfortunately, I was passed the allotted 30-day "downgrade to windows 8."
- From Microsoft.com I downloaded the ISO image of Windows 8 onto a USB and tried a few different...keys. Though the new key worked, I learned that my hard-drive was "reserved for Windows 8 OEM." After much research, I was warned against deleting it UNLESS I was an "IT guy", which I am not.
Also, it's fair to add... I recently obtained adware of some sorts from a download. (About 5x through every hour, my command prompt pops up and my internet browser automatically routes me to one of many different sites like "Roblox.com, Terraclicks.com, test.com" and After using countless removal softwares (Malware Bytes, AdwCleaner and tool, Norton, Hitman Pro, AND BitDefender) I still have the same issue.
SO, I thought...Maybe I should just buy a new hard drive and key for Windows 8.1 (I have the ISO image on USB now) and that'll solve all my issues at once. Then I learned that my windows 8 OEM may be "Keyed" to my motherboard and that it may not work...?!
I'm at a loss for what to do at this point. What I know is...I need Windows 8 or 8.1 (NOT PRO) to run Pro Tools 11. I would also like to have my computer back in my full control (ADWARE or WHATEVER IT IS, GONE) and I don't have very much money to invest at this point.
Will buying a new hard drive and OS key work as a resolve or is there a better way? Also, what do I do about my "OEM Reserved" hard drive? Any and all suggesting or answers would be appreciated.
Thank you...
Thank you...
