I have an $1800 gaming PC and sometimes it just randomly BSOD's all day on certain days and then is fine the next. I am not too concerned with this at the moment but I just thought it would be worth mentioning. Last time this happened, it turned out my RAM sticks were garbage and I needed new ones.
Anyway, my main problem is that my "Gaming PC" seems to crash a lot during certain games when I play them on the settings that the game itself recommends for me (which ranges from High - Ultra). In the past this has happened with games such as Blacklight Retribution, Gotham City Imposters, and Metro 2033, but I never concerned myself too much with them since I don't like them that much anyway.
However, I recently started getting into DayZ, the ARMA II mod. When I first installed ARMA II and ARMA II: Operation Arrowhead, they worked fine. Now, my computer BSODs before I can even get into the video options within the game. I have given up trying to figure this all out myself, so I would appreciate the help.
Here is my most recent minidump file from ARMA II crash
https
/dl.dropbox.com/u/35897371/031113-24148-01.dmp
Some Specs:
Intel® Core™ i7-3820 Quad-Core 3.60 GHz 10MB Intel Smart Cache LGA2011 (All Venom OC Certified)
CS_FAN: Default case fans ENGRAVING: None FA_HDD: None FAN: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
HDD: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Drive)
MEMORY: 8GB (2GBx4) DDR3/1600MHz Quad Channel Memory (Corsair or Major Brand)
MOTHERBOARD: (3-Way SLI Support) ASRock X79 Extreme 4 Intel X79 Chipset Quad Channel DDR3 ATX w/ UEFI bios, XFast LAN, Charger, & USB Technology, 7.1 HD Audio, GbLAN, USB3.0, SATA-III RAID, 3 Gen3 PCIe X16, 2 PCIe X1 & 2
OVERCLOCK: No Overclocking
POWERSUPPLY: 800 Watts - Standard Power Supply - SLI/CrossFireX Ready
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: NVIDIA GeForce GTX 580 1.5GB 16X PCIe Video Card (EVGA Superclocked)
EDIT: Also worth mentioning, there is always a click noise that comes from my computer before the BSOD.
I suspect that it is either a Video Card or HDD issue. Maybe Power Supply, I don't have enough experience with this stuff to tell.
https
Some Specs:
