alexoiu :
Check the PSU cable that says Perif.
doesnt matter mate,nzxt have put the wrong plug on the fan controller,it needs to be a female socket!!
Ive never seen a psu in my life that comes with female molex,only male
EDIT
I need some more sleep - I havent used molex plugs for that long Im getting mixed up - as alexoui says this will plug straihgt into your psu cables - you should have a string of 4 molex cables with the psu
apols for my previous stupidity - Im off back to bed
the cable you want is the centre one on the right - it has 4 plugs & you can clearly see perif on the psu socket plug
