Can't Find Orientation for Front Panel Connectors (H81M-Vg4
Enzim8
49
Hi i can't find the front panel connectors for the H81M-Vg4 motherboard. My computer worked fine an hour ago until i installed a new fully modular power supply in and it seems to work aswell.
When i plug in the power supply the light on my mouse lights up (which i assume indicates power)
and when i unplug it the light turns off.
Does anyone happen to have a manual of this motherboard so i can figure out the correct orientation of the front panel connectors?
Welp, I put the plug for the old psu in the fully modular and it worked then I turned it off to see if it would work again and it didn't so I put the old psu back in and it works again so I just sent back the fully modular and got a refund.
