Really sorry for the bad english.
I have an aspire sw3 013, with a 500gb HDD.
It had windows 8 installed, and there was this free windows 10 installation, so I did install. After the whole process I did a factory reset, because it had another person account. After that the HDD didnt worked. So I went to the Driver Manager and tried to format it. Before doing it, it asked to initialize, so I did, and it gave me an error (incorrect function). After that the options stayed gray and it wont let me create another partition or format it. Then I used DiskPart and cleaned it. But it still didnt worked. So I used an USB with windows 7 to format it, and I was using a 64gb microSD, so when I runed the program I dont know what happened but it asked me to format the 64gb microSD, I told it no, and after that I tried to format the 500gb HDD but it didnt worked, so I stoped the program. Then I connected another 16gb usb, and after that I got two error messages that the 64gb and the 16gb usb have to be formated, I try to format them but in the options the 64gb microSD will only show 5gb and the 16gb one will only show 32mb, and none of them will format, there is a message the format did not complete.
It's so weird, and I feel really bad, cause I messed up so hardcore. Help me please.
