cant get my acer 27 in 3d monitor and ps3 to work on 3d help
I dont no. Will ps3 3d glasses work with my ases 27in 3d monitor if yes how
O ya the mon is the last one on ur list
PS3 glasses will not work, but the glasses that come with the monitor will work with the monitor, and I do believe the PS3 as well.
Make sure the glasses are charged.
You need to go into the Nvidia control panel, go to the 3D vision page, and run the wizard to get it setup. Once setup there, it'll be available in game, but not all games work well with 3D Vision. For some of those games, go here for a fix: http://helixmod.wikispot.org/gamelist
It is mandatory that you run the monitor through a dual link DVI cable.
Yeah, that monitor uses 3D Vision glasses and 3D Vision 2 glasses also work, which I have started using. They are far more comfortable.
Oh, and the Dual Link DVI cable is for computer 3D Vision gaming. Use the HDMI port for HD3D and I believe PS3.
