Can't monitor CPU Temps
User1001
32
Hi guys, as the title says i can't monitor my CPU temps with any software. I was able to do so before, but now something happened and everything i install doesn't show CPU temps. Any ideas?
Sorry, I had forgotten that your system is too old. You don't have much of a choice; if being able to monitor the CPU temperature is really important, then you may have to replace the motherboard. However, I have a few more questions.
- Is the CPU temperature displayed in the BIOS?
- Have you tried booting from a different source, e.g., https://falconfour.wordpress.com/tag/f4ubcd/ and used the included HWmonitor? Does it also fail? If not, then something in your OS prevents monitoring tools from working.
If it can't be detected in the BIOS and the rescue DVD, then the...
CPU: Core 2 Quad Q9450 2.66 GHz
MOBO: Rampage Formula 1
OS: Win 7 Ultimate 64-bit
GPU: GTX 580
RAM: 2x2GB Samsung DDR2 800 MHz
PSU: Antec TruePower Quattro 850 W
If it can't be detected in the BIOS and the rescue DVD, then the sensor definitely is no longer working.
I looked at the temps on BIOS, and always displays the same number, 20 degrees celsius. It never changed while i monitored it for 5 minutes, the temps of motherboard and other parts had ups and downs, but not the CPU temp. Also 20 degrees is impossible to be true, my CPU idles at around 38-40 degrees celsius.
Nah, it's fine, i just found it very odd that i couldn't check my temps anymore. Thanks for everything 😀
Latest posts
