Can't overclock my Intel i5 3570K Help!
Alokin
4
hello i recently upgraded my cpu and mb and now i have the Intel Core i5 3570K 3.4 GHz Ivy Bridge and the MB ASUS B75M-plus
today i try to OC the cpu but i was blocked because the ratio wont go over 34!! 🙁
so here are some screenshots, try to tell me if i'm doing something wrong
http://imageshack.com/a/img841/3710/ujhy.png
http://imageshack.com/a/img22/7627/jmpr.png
http://imageshack.com/a/img69/1877/jny7.png
http://imageshack.com/a/img189/2120/5g15.png
thanks for the fast reply
in other words, with this motherboard i can only keep the stock cpu ratio, not even going 5% more?
is it possible to flash a similar bios to unlock the overclock?
Try getting a 1st-release BIOS 😉
Some of them enabled overclocking anyway..until Intel raised a fuss.
The BIOSes may not be on vendor website 😉
They're not on Softionic, though. 😀 Make sure you stick to forums..
i found this on the asus website
B75M-PLUS BIOS 0209
First release Bios
is it safe to downgrade the bios?
YES! It might be kinda hard though..See if you can DL the BIOS 1st 😉
Here's how if it gives you problems (It probably will)
http://www.overclock.net/t/1291819/solved-how-to-roll-back-3207-bios-on-p8p67-deluxe-pro
thanks for the advice, but it didn't help, even the original bios version don't allow to go over the cpu stock ratio, i think is the b75 chipset that don't allow the overclock, I will move to the Z77 as soon as possible because of the "K" processor...
