I need help fast, so please help me!
For the last 8 months since I built my computer, I have been using wireless internet on my computer, and I have been getting on fine. Now I have to move my computer elsewhere in my house, but I needed a wireless extender, so I got myself a 'TP-Link AV200 Powerline Adapter with AC Pass Through Starter Kit'. It works by plugging in one adapter near the router, plugging and ethernet cable into the router and the adapter, then placing the other adapter near your computer, and plugging the ethernet cable into your computer and the adapter. Then the adapters connect wirelessly, and provides you with an internet connection. The problem is, however, when I tried to plug the ethernet cable into my computer, it did not fit. There was some sort of tab from my I/O plate preventing the small notch at the top of the connector from insterting into the port. I don't want to try to force the cable in and end up breaking it, but I need to be able to plug it in.
I hope that someone can help. Thanks!
