Hello everybody, so I just moved into a new house and it is wired with ethernet. The patch panel is in a closet and all the rooms have cat5e jacks leading to it. In the patch panel itself the ethernet cables are just hanging out of the wall with the plastics ethernet plugs at the ends of them. So one room is going to have a computer wired another, a router, and another, a modem. The modem and router are in different rooms because it is a cable modem thus needs a cable connection which would be a little impractical for where I am going to place the router. Now that the background is out of the way lets get to the dilemma. As I said above I have a computer, a modem, and a router I need to connect them together through the patch panel, to do this I would use a switch but there is not a single power socket insight in the closet. So how in the world am I going to power the switch. I thought about using PoE but I'm not sure how that really works and if there are switches that work with it in the first place. Sorry for making you read all this but if you could help it would be greatly appreciated. Thanks.
