So I had turned off the undervolt on my CPU a few months ago and now I'm trying to reapply it. Problem is when I adjust the PBO settings I'm sure the BIOS isn't saving the changes for the undervolt. It always says "you have not made any change to the BIOS settings" when I go to exit whereas if I adjust the XMP profile it alerts me that it has been activated/deactivated.
I've tried going back to the old bios I used when I had undervolted before and I still can't save the settings. I was wondering if it was the CMOS but every other setting (changed xmp profiles, fan speeds) saves on the bios except for the amd overclocking section.
Any idea what is going on? MOBO is MSI B550M using Click BIOS 5. Thanks
