[SOLVED] Can't set my RAM speed to anything higher than stock (2133MHz) ?
Mortka
Commendable
Feb 3, 2020
24
Basically, I can't adjust my RAM speed to anything higher than stock. I've tried to manually change the BIOS settings using DRAM calculator, but without luck.
Heres my specs:
RAM: Corsair Vengeance RGB PRO DDR4 3600MHz 16GB
CPU: AMD Ryzen 5 3600
GPU: Asus RTX 2070
The RAM is basically brand new, bought it a couple of months ago and I can't seem to get it to work properly.
UserBenchMarks test:
https://www.userbenchmark.com/UserRun/45718067
Thank you for any information I might get.
Heres my specs:
GPU: Asus RTX 2070
Try to update to the latest bios, and try to use XMP, dram calculator have no guranteed success rate.
Heres my specs:
GPU: Asus RTX 2070
Mortka
Commendable
Feb 3, 2020
24
Mortka
Commendable
Feb 3, 2020
24
Yep just thhe latest one (f62 iirc?)
That is correct. I've just heard weird things about updating BIOS, and dont really have a clue what it does.
  1. "Update AMD AGESA ComboV2 1.2.0.3 B for Ryzen 5000 G-Series processors support"
Now, I dont have a 5000 series, so should i actually download this?
Yes, the latest bios Update also dded support to the latest CPU. You should be just fine :D
