cant turn o turbo control help
mangoman300
4
well I just got amd overdrive and decided to mess around I got my prossesor buffed up with the turbo control then turned it of and cant turn it back on now im only running at 3.4 ghz
Try resetting your bios. Clear cmos... or load setup defaults/optimized defaults.
Also it might be a good idea to check if there's a bios update and update it if there is... could be a bios bug
