HI
Replacing 2 capacitors on Motherboard. Found identical spec but shorter in hight capacitors will they be ok?
Also will be using Lead Rosin Core solder will I still need Flux to dip iron tip in? If so what kind of flux?
Will be getting solder sucker and wick as well
Thanks
Thanks
