I was wanting to replace all the capacitors on my XBOX circuit board, since I have made a case for it, with see through panels, green coolent etc., the addition to smaller, maybe golden capacitors would make it look much more attractive.
Starting off, I was wanting to replace the very large, 820UF 6.3V capacitors, on the board. I was looking at these off eBay, and was wondering if they would likely be compatible and work with the rest of the components:
http://www.ebay.co.uk/itm/5-X-CAPACITOR-820UF-6-3V-Part-PLE0J821MDO1-/390461119507?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item5ae94bdc13
If so, is it safe to spray paint the capacitors, using non-conductive, with extremely high boiling tempreture, products? I feel it would cause no problems, but don't feel 100% with it..
