cAPS LOCK cONStanTLY tOGgLINg AND WONT fiX ITSELF
Dr_Tee
8
TItLE sAyS IT ALL, aS YoU cAN SEE ItS AS iF My CaPS LOCK KEY Is tUrNiNG ON AND oFf aGAIn VEry RAPIdLY MAy aLSO BE BeCAuSE OF MY SHiFt Key CONSIDERING IF I pRESs IT ENOUGH TiMEs it RESoLVES THE ISsUe FOR A sHORT wHILE, This iSSuE PerSISTS eVEn WHEN SWITCHinG kEYBOArds so THIS mAy nOT be THE BeST plACE tO PuT ThIs, bUT I Had no iDeA wHERE ELSe To go>
I ApOLOGiZE FOr My INABILITY tO ConTRoL The IsSuE, I WOULD have PREfERED To TYPe THIS wITh PRoPER CaPiTALIzIaTiOn But ThAT WASnT NeCEssaRILY RealIsTIC< ANY ANd All ANSWERs aRE APPRECiAtED.
You didn't mention the keyboard type but my first suspicion is something caught under the keys. Have you used canned air? Pulled the keys off to look at the switches (look online for how to do so on your keyboard)?
aSI mENtiONED< the iSSuE pERSiSTS EveN WHeN sWITCHING To a BRaND NEw KEYBOaRd
Well, based by the chevron instead of a period, it's actually your shift key. Try popping it off with a knife or something, it won't damage it. See if there is something cracked, damaged, sticky, or otherwise off underneath the key.
