I was thinking of getting a capture card as I want to record my gameplay and possibly stream it but I've encountered some issues.
PC Specs:
CPU: AMD FX-6300
GPU: Nvidia GeForce GTX 1060 3GB
Motherboard: Gigabyte 990-FXA UD3
RAM: Corsair Vengeance 8GB DDR3-1333
I have used OBS and tried to stream with it however the quality is terrible.
OBS Settings:
Encoder: H.264 or NVENC
Bitrate: 2000-2500
Frame Rate: 30 (Downscaled from 60)
Resolution: 720p Max (Downscaled from 1080p)
There's an impact on game performance when I try to stream and the stream doesn't look so good either.
Would a capture card help?
I was thinking of getting the Elgato HD60 Pro as I have free slots on my motherboard and I could get one quite cheap. I figure this is my only option to make good recordings or content overall as I can't upgrade nor can I change tariff or ISP to have everything better internet.
Any suggestions?
PC Specs:
CPU: AMD FX-6300
OBS Settings:
Bitrate: 2000-2500
Any suggestions?
