is it good to use car coolant?
i found it in garage and the car coolant description :
-does not contain Ethylene Glyco
- it has water pH 7 standardizing
-contains FTHL (Fast Heat Transfer Liquid)
-using Reverse Osmosis
-with the latest innovations using Hydro Lube Oil
or buy pc coolant? do i need destiled water for pc coolant ? (the coolant that made for pc)
