Carbide Air 240 Airflow
uAurorax
16
Hello , I'm getting corsair Carbide Air 240 uATX Case soon
but i heard that it has 80mm fan and its airflow isn't that good
i'm building it with GTX 1070 maybe OC'ed and stock i5 6600 non K
will the case fans be enough for gpu ? the cpu will be at stock speed so it will be ok with stock fan
(sry for bad english)
If you have concern over the chassis, you could look into a similarly designed case by Fractal courtesy of the Node 804. If you can't go that latter's route the case as is will be more than enough. You yet have the top fan mounting positions to ventilate the heat from your chassis in the Air 240.
