Care to help out an overclocking virgin?
G
Guest
Guest
With these specs:
Gigabyte GA-MA78GM-DS2H
AMD Phenom 9950 Black Edition CPU 125 Watt Edition
4GB Kingston HyperX 1066GHz Ram
512MB HIS IceQ4 Radeon HD4850 GPU
650 Watt Alphapower PSU
This case:http://www.newegg.com/Product/Produc...82E16811163058 (has to be a mini tower as space is a massive issue)
And this cooler: http://www.frostytech.com/articlevie...id=2271&page=1 (assuming I can get it in the UK)
How well do you think the Phenom will hold up to a 3GHz overclock? Any suggestions? Do you think I could take it higher?
khelben1979
177
To be able to make a decent analysis of what powersupply you need if you're going to replace it, you should have a look at this place over at DriverHeaven.
The Corsair at 750W is a good choice (even though 750W is more then you need, it makes it more quiet.)
