Need an ATX case that will fit in a 18 1/8" opening that my computer cabinet has. This is not really negotiable per my wife.
The Fractal Midi R2 is 460mm (18.11"). I believe this is without the feet.
The Corsair 200R is 428mm (17.25").
Those are the only two highly rated cases I see that will fit. I prefer the R2, but am I going to run into any cooling issues with their being so little clearance on the top and not using the feet?
The other issue is I have a 390X already with plans to get another one. The Asus STRIX 390X is 11.8" long. I don't believe two will fit in the 200R, nor will my preferred cooler (Noctua NH-D15). The R2 will fit two STRIX by removing the top hard drive bay (which I won't need) and it also fits the NH-D15.
Anyone have any advice or can perhaps recommend another case I'm not seeing?
Also can't be wider than 10.5"...
