Either. Doesn't matter. There will be virtually no cooling difference. If you want SILENT fans, get Noctua's. Also you need rubber mounts.
The stock fans will be perfectly fine. If you replace them, it really is ONLY for looks or more quiet fans, not better cooling.
Set the fans up in the orientation I explained earlier for optimal cooling.
