Case and CPU cooling.
Vorterix
29
Hello.
I would like to get some cooling ideas.
Custom water cooling loop is out of the question.
What case fans should I use?
What CPU cooler should I use?
My case is Corsair Vengeance C70 and CPU is Intel i7-4790k.
I am looking for something pretty silent but still efficient, can't forget the looks of course :)
Thank you for your opinion!
What kind of budget are you allocating to this project.
Personally I don't like Noctua's color scheme, but a good looking cooler that matches the NDH-15 in performance (both in noise and cooling) is the be quiet dark rock pro 3.
On the cheap end the winner is almost always the Cooler master Hyper 212 EVO. It will cover you even with mid level overclocks.
Xibyth
Thank you for your opinion.
I looked at the dark rock 3 and it looked like a good choice. My budget for case fans would be something around 100€
Your reply helped me alot
Thanks mate :)
