Question Case and CPU temp
Apr 14, 2019
6
Hi guys, just finished my first build every and asking for advices on cooling temp. Provided that i think i-ve put enough cooling paste, my case is made of wood in the front, 5 mm plexiglass on sides and back , 2mm aluminum top and bottom.
I have a B450 fatality ASROCK motherboard
Ryzen 5 2400g
PicoPSU internally attached to an external power brick.
No video graphic, i will use this pc for some basic home recording.
Without cover, it runs on less than 30 degrees average... with the cover stays around 38/40 with peaks at 58. These temperatures are recorded by simply surfing the internet, some youtube and typing this post.
Do you think is good? Bad? My room temperature i guess is around 25 degrees right now.
Thanks a lot!
Pictures below
https://ibb.co/hm4wYKx
https://ibb.co/wJLNDD7
https://ibb.co/ZWQbQ3d
