W wagner_alexandru May 11, 2018 21 0 10 May 15, 2018 #1 Can this https://altex.ro/placa-video-asus-nvidia-geforce-gtx-1050-ti-4gb-gddr5-128bit-cerberus-gtx1050ti-o4g/ go whit this https://altex.ro/carcasa-zalman-t3-zm-t3-1-x-usb-2-0-1-x-usb-3-0-matx/
Solution T T tully.stott92 May 15, 2018 The Zalman T3 supports graphics cards up to 250mm with the hdd cage installed, and the gpu is just over 200mm long so yes they will work.
T tully.stott92 May 13, 2018 17 0 40 May 15, 2018 Solution #2 The Zalman T3 supports graphics cards up to 250mm with the hdd cage installed, and the gpu is just over 200mm long so yes they will work. Upvote 1 Downvote Solution
