Case and Graphics Card Measurements.
The GPU itself doesn't really matter, still would be nice to know though, but the G1 cards with the windforce 3x cooler will require you to remove one of the drive bays in your case. The G1 cards with the windforce 2x cooler should fit without needing to touch the drive bays.
EDIT: Yeah the GTX 970 G1 will require you to remove one of the drive bays, the GPU is 312mm long and the case with the drive bay in fits up to 300mm, 420mm without the drive bay.
The case supports cards up to 300mm in length, or 420mm if you remove some HDD cages. Unfortunately, that graphics card is 312mm in length, just 12mm too long, so you'd have to remove HDD cages. Considering the case has like 8 3.5" drive bays and 3 2.5" bays, that will not be any problem removing one or two. Or just buy a smaller card and not remove the HDD cages.
Edit: modernwar beat me to it.
