Question Case and power supply compatibility.
Nov 7, 2021
Hi, quick question. Can someone tell me if those power supplies will fit in a SilverStone Alta F1 case?
  • be quiet! Dark Power 12 1000W and
  • be quiet! Dark Power Pro 12 1200W
Thank you in advance :)
Aeacus
Glorious
Ambassador
Just look the clearances.
Your case, with 3.5" drive bay installed, has 160mm max PSU length clearance,
specs: https://www.silverstonetek.com/product.php?pid=991&area=en#fgo-spec
This is 175mm long,
specs: https://www.bequiet.com/en/powersupply/2151
And this one is 200mm long,
specs: https://www.bequiet.com/en/powersupply/1923
So, none of them fit.
As far as how much clearance you get when you remove the 3.5" bay - that you need to ask from Silverstone (or anyone else who has that case).
