Case beeping help
Rawberries
Commendable
Sep 29, 2016
53
Ever since I bought my case (nzxt guaridan 921) it have been "beeping" everytime I turn the pc on. Anyway to fix this issue? (I've already taken the gpu out)
I would definitely recommend you keep it in for this reason. It is much easier to diagnose a boot problem if you have beep codes. The first thing anyone will recommend is putting a speaker on the board to get the beep codes if the machine does not boot.
It's annoying when i just want to start my pc.
If the speaker is the removable kind, like at the link below, you can simply unplug it from the motherboard.
Motherboard Speaker
How many times in a day do you restart your PC?
Mine gets restarted may be 1-2 times in a month.
Beeps during startup doesn't bother me. But it's usable feature in case something goes wrong and pc doesn't boot properly.
