Case Compatibility for H105?
Nov 22, 2015
5
Hi guys, I was just wondering about case options that are compatible with the Corsair H105 Liquid Cooling System. My budget is kinda of tight so anything that ranges from maybe $170 AUD and lower is fine. I can't afford anything higher than that at the moment. Thanks!
PC cases providing mounting points for 240mm (dual 120mm) radiators., either top mount or front. though front mount at times is not viable as hdd cages are often there and need removal for fitment .Makers usually state this in there specs.
Pick some you like and post links here
