E edgelord3941 Mar 6, 2018 1 0 10 Mar 6, 2018 #1 I've recently bought a Zaliman Neo N1 and a Gigabyte A320m m.2 for my Ryzen 5 1400build, and I forgot to read up if they're compatible and there's not enough case cables for the front board panel. How can I fix/remedy this?
Solution clutchc Mar 6, 2018 There should be unless the factory assemblers screwed up. Check out this Newegg video around 2:36 and see if your wires match the ones in the pic/vid.
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Mar 6, 2018 Solution #2 There should be unless the factory assemblers screwed up. Check out this Newegg video around 2:36 and see if your wires match the ones in the pic/vid. Upvote 0 Downvote Solution
