Case Cooling Advice
GreenandSlimy
48
My computer specs are
Rosewill R5 Black ATX Gaming Case
Gigabyte z97x-SLI Motherboard
Intel i5 4670k 3.4ghz Oc'd to 4.2 Ghz Processor
Hyper Evo 212 CPU Fan Cooler
XFX R9 280x 3gb Double Dissipation Graphics Card
Corsair Vengeance(LP) 8gb DDR 3 1300mhz Oc'd to 1600mhz Memory
1tb Seagate Barracuda 7200rpm Storage
My concern is that when I'll run a game for about 20 minutes the exhaust air in the back of the case is super super warm. Is normal? Or does this mean I need to upgrade my case fans and or my CPU Cooler. If I do what fans should I replace or If I should simply just add more fans to make my system cooler.
Any airflow fan should help. I'd recommend a Noctua or Corsair AF. Both are considered to be the best, but it's up to you on how much you want to pay/looks/deals (might be able to get a combo with extra fans
Alright will look into those! Thanks!
