G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Most sites have seen recommend you blow air out of the case, and if possible
have air intake in the front to create airflow through the case. Blowing air
out simply means that components don't overheat for example powersupplies
and vga coolers. I also know that if you open the case and stick a fan
beside it everything cools, the hd cools, the motherboard cools even the
powersupply cools. So has anyone tried turning all the fans so they blow air
into the case? hotter case? cooler case? no difference?
